Ignition coil replacement part number
I need to replace an ignition coil, but I'm seeing multiple part numbers for the OEM part. As the coils seem to be a weak point, I want to make sure I get the most robust version. Which part number seems to be the most reliable? Or is there an aftermarket option that's less prone to failure?
I found a Denso coil (part number 673-1309) that's about half the price of OEM. Any chance this is the same part as OEM?
90919-A2007, it is the most updated coil and supposedly isn't as prone to failure as some of the prior ones.
Use MyLparts, here's a link to their site:
https://www.mylparts.com/oem-parts/l...bC12Ni1nYXM%3D
less expensive here
https://www.parts.com/index.cfm?fuse...-IGNITION-COIL
Even cheaper here
https://parts.mcgeorgetoyota.com/oem...oil-90919a2007
Even cheaper here
less expensive here
Even cheaper here
Even cheaper here
RXy
RX - 1st Gen (1999-2003)
14
04-02-17 06:08 PM
MyFerocity
03-23-12 05:02 AM
