Could you post your OEM HID beam pattern?
Old 07-02-17, 10:16 PM
joedaddy1
joedaddy1's Avatar
Talking Could you post your OEM HID beam pattern?
I just replaced my low beam HID w AFS using Osram CBIs.
Beam pattern looks a bit off.
i have a pretty pronounced "squirrel spotter" going on (eye brows)..
trying to figure out if this is normal or if I messed up...
Attached Thumbnails Could you post your OEM HID beam pattern?-img_0001.png   Could you post your OEM HID beam pattern?-img_0003.png   Could you post your OEM HID beam pattern?-img_0005.png
Old 07-03-17, 07:32 AM
05RX330AWD
05RX330AWD's Avatar
From the RX330 Service Manual...
hopefully this helps
Attached Thumbnails Could you post your OEM HID beam pattern?-capture.jpg   Could you post your OEM HID beam pattern?-capture1.jpg
joedaddy1 (12-23-23)
Old 07-03-17, 02:51 PM
TommyTT
TommyTT's Avatar
Default RX 2nd Gen headlight aim
R/H diagram ok but don't understand L/H diagram. Please explain.
Old 07-03-17, 10:06 PM
Lexuswiz
Lexuswiz's Avatar
Definitely not normal, are you sure you installed the bulbs in the right orientation? The grounding probe should be facing the bottom of the headlight housing.
janesmith (12-25-17)
Old 07-04-17, 11:24 AM
joedaddy1
joedaddy1's Avatar
Yea... found out this is normal for 2nd gen RX. Especially 350/400h series
Old 07-04-17, 05:10 PM
Lexuswiz
Lexuswiz's Avatar
Hmmm interesting, I noticed your cutoff isn't sharp either compared to my RX330 and retro'ed Camry (using MDX projectors). Can't believe Lexus did this on the 350/400's....
Old 07-04-17, 05:14 PM
joedaddy1
joedaddy1's Avatar
Well, supposedly the retrofitters prefer rx330 projectors over 350/400... maybe it has a better cut off.
lets see how these CBIs do on the RX
Old 07-04-17, 05:29 PM
Lexuswiz
Lexuswiz's Avatar
Keep us posted. It's funny, my generation Camry cannot fit the rx350 which is what I wanted, only the MDX fit with little modification. I'm just surprised I can barely see your cut off line while the squirrel spotters are so bright like a non-HID setup.
Old 07-05-17, 06:41 AM
takeshi74
takeshi74's Avatar
Definitely not normal. I don't have photos on hand for our 400h but will see if I can take some.
Old 07-09-17, 09:39 PM
neelnaik
neelnaik's Avatar
Old 07-09-17, 09:40 PM
neelnaik
neelnaik's Avatar
It's an old pic, but it's a 2004 RX 330 no AFS with Osram CBI bulbs
Old 07-09-17, 09:46 PM
joedaddy1
joedaddy1's Avatar
thanks.. i am assuming that was at least 20 feet from the wall? I did read that RX330 had small spotters that were 3 small holes. This explains the faint dots in your photo. Supposedly Lexus installed a bigger, horizontal spotters on the 350/400h.. which explains the small rectangular boxes in my picture.
Hmmm... still the plot thickens.. i would love to see a picture from other models.. close to the wall (3-5ft) and farther... 20+ ft.
Old 07-09-17, 10:02 PM
neelnaik
neelnaik's Avatar
No problem! I honestly don't remember where the car was in relation to the wall. I took that pic in 2012 when I first put the CBI's in. They are about due for replacement now. Off topic, but I am probably going to go back to something with a warmer color temp (4600K or so). I don't know if I am just spoiled by other cars, but the CBI's seem to suck in the rain, but they are awesome when it's dry. I haven't ever driven a 2nd gen RX 350 or a 400h at night, so I couldn't tell you.
Old 12-19-17, 05:54 PM
SpectraBlu
SpectraBlu's Avatar
Op- did you ever figure this out? I changed bulbs in 09 rx350 and same thing is going on. It wasn't like that before changing bulbs. I'm thinking it's something with bulb seating, but it's so tight in there its hard to see. Thanks
Old 12-19-17, 08:22 PM
joedaddy1
joedaddy1's Avatar
Hi, it’s still the same. I just brushed off as my CBIs being brighter than stock. Personally these bulbs are not too great.
Quick Reply: Could you post your OEM HID beam pattern?
