2008 RX-350 Rear rotor removing tips
Old 07-28-17, 08:31 PM
wzwz8221
10th Gear
wzwz8221's Avatar
Default 2008 RX-350 Rear rotor removing tips
I have just replaced my rear brake rotors and would like to share a tip on removing the rear rotors.
Car: 2008 RX-350, all wheel drive.
In order to remove the rotors, I had to do the following:
1. put the car in neutral (DO make sure you are on a leveled ground and with enough force/blocks to stop the car from rolling)
2. release the parking brake
3. rotate the rotor so that the access hole is at 6 clock postion, then use a flat screw driver to get into the access hole and turn the adjustment gear down until the rotor is freed from the parking brake pads.
Step 1 is necessary or you won't be able to position the access hole at 6 clock position.
-Wayne
Old 07-30-17, 07:42 AM
cdnewton
cdnewton's Avatar
-Wayne
Really good tips and the stuck rear rotor is a real pain .. having done that recently, which direction did you turn the adjustment gear?
Old 07-31-17, 05:04 AM
wzwz8221
10th Gear
wzwz8221's Avatar
From up to down.
DO make sure the car is on a leveled ground and use enough blocks to stop the car from rolling since the transmission is in neutral position.
Old 07-31-17, 09:55 AM
cdnewton
cdnewton's Avatar
From up to down.
as in CCW?
Old 07-31-17, 10:24 AM
5W40
5W40's Avatar
Old 07-31-17, 11:58 AM
cdnewton
cdnewton's Avatar
Originally Posted by 5W40
Excellent, thank you. I have saved the information off for next time.
I, unfortunately, did the BFH approach and got it off that way. I knew something was holding it on (besides being stuck to the hub), but I had already broken part of the parking brake assembly (see highlighted image below with the part fixed), thus I continued to hit it until it came off. I was frustrated and couldn't figure it, so I paid a mobile mechanic to come out; he fixed that in about 5 minutes and then I finished the brake job. Still much cheaper than taking it into a shop, I got some tools out of the deal and I learned a lot.
prech (01-09-20)
Old 01-10-18, 11:29 PM
FloorJack
FloorJack's Avatar
I bent those pins as well.
When changing the back rotors definitely have some new rear brake hardware on hand...
prech (01-09-20)
Old 10-25-18, 06:01 AM
azcat90
azcat90's Avatar
Default 2 minute solution
Remove one of the 12 mm valve cover bolts and screw it into the 2 screw holes on the rotor to pop it off. Put bolt back.
yonswizzle
08-09-19 12:29 PM
gmacrae
02-16-12 02:16 PM
Max Power
12
07-16-10 02:59 AM
trhs75
RX - 1st Gen (1999-2003)
09-21-09 08:46 AM
shikbas
12-22-08 05:25 PM
Quick Reply: 2008 RX-350 Rear rotor removing tips
