Engine oil api sm or api sn in 2006 rx 350
Old 08-09-17, 01:48 AM
tomr51
tomr51's Avatar
Default Engine oil api sm or api sn in 2006 rx 350
The manual states API SM, but the latest standard is API SN that is "backwards compatible"
Are people using the API SN in 2006 RX 350s?
Old 08-09-17, 08:17 AM
kennytbone
kennytbone's Avatar
You're way over thinking a simple oil change, but yes, everyone uses API SN. As long as you buy a good name brand oil, all you need to worry about is the weight, and even then you just need to be close. A 20 or 30 weight with any available w value will work just fine.
edit to clarify that you're unlikely to find a name brand motor oil that is still made to API SM. When a new standard comes out, most of the oil manufacturers reformulate fairly quickly to meet the new standard. The RX has fairly basic oil requirements, so any name brand of suitable weight should be fine.
Old 08-09-17, 10:43 PM
tomr51
tomr51's Avatar
thks , you have confirmed my thoughts.
roboost
RX - 3rd Gen (2010-2015)
22
08-27-15 05:56 AM
espressoRX
11-18-10 07:47 AM
mmlex1987
12-08-09 05:17 PM
relax221
07-28-09 06:04 PM
Quick Reply: Engine oil api sm or api sn in 2006 rx 350
