moonroof reset
with both controls, the moon roof does not operate correctly. when you close it, it goes to the close position, but then keeps going and opens again. to close it you need to judge when to turn the switch off, and hope it is fully closed.
Is there an ecu reset i can try? is there an adjustment sequence i can do?
i used this reset and it fixed the problem
IG "on"
push/hold tilt button
roof will tilt open,then close, then slide open, then close
release the tilt button and moonroof is reset.
IG "on"
The following 3 users liked this post by tomr51:
These instructions appear on the Manual, as well.
jtbmoore
GX - 1st Gen (2003-2009)
12-21-05 03:35 PM
