Urgent! Door dead lock
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_2176_c83df9a8299439d4fc36041803e5e4817fe99a2a.jpg)
Hi I am replacing my rear door due to damage. I took the door card off. And release the green and white cables, photo above . When test fit it back, I simply hook the 2 cables in. Now the door lock and unlock from the driver control and the remote key, but physically I can't open the door from inside or outside!!! When I open the door from inside the green cable doesn't move ( as it's stuck), the handle lever is hard not moving. I don't want to break anything. Is there a procedure to reset anything? From outside I can pull the handle (no resistance) but it does nothing to the door??
please can anyone help?
I figured out what happened, when I put the white cable in it's already in Lock position hence can't get the door opened. Have to pry the door card and pull the cable by hand to release the door!
gulleyman
GS - 1st Gen (1993-1997)
15
09-19-21 08:05 PM
