Windows not working from Drivers door
Old 09-29-17, 01:46 PM
tomr51
tomr51's Avatar
do not believe the logic, but if it now works the result is great.
Old 10-06-17, 07:38 AM
Tucketgirl
Tucketgirl's Avatar
Originally Posted by mandyfig
This condition normally happens when the battery is disconnected. The manual actually outlines on how to re-set the windows so that the driver can control all of the windows. If memory serves me right, you have to cycle the window that does not work by remote 3 times (down-up x 3), then try to control via the driver’s control.
If the above does not work, I would disconnect the battery and re-learn everything (that’s what I would do). When you disconnect the battery, you will need to re-set the seats and side mirrors re-taught (re-set) and well as the sunroof.
Good luck.
What does 'by remote' mean? My passenger side window also does not work from the drivers side window controls. I want to try the 3X thing but what does by remote mean?
Old 10-06-17, 09:35 AM
DennisMik
DennisMik's Avatar
He means from the master switch in the driver's door.
Old 05-21-24, 08:18 AM
drewbobby
1st Gear
drewbobby's Avatar
Default Well that was almost too easy
[QUOTE=tomr51;9969192]take window half way down then all the way up. hold the switch in the up position for a few secs after reaching the top. do this with each window from the window switch.
couldnt have been any easier 30 seconds later and all the switches from the drivers door are fixed and operating the windows again
roccodog
02-17-19 03:41 PM
jbyham
GX - 1st Gen (2003-2009)
35
02-07-16 01:40 AM
one2nite
08-17-13 06:29 PM
gqr1c3boi
04-26-09 01:45 PM
NetJunkie
05-25-08 08:48 PM
Quick Reply: Windows not working from Drivers door
