timing chain broke
Old 10-03-17, 09:31 AM
jostapf
jostapf's Avatar
Default timing chain broke
timing chain broke on lexus rx350 2007 do I need a new engine, how much would this cost? just an estimate.
Old 10-03-17, 07:29 PM
DennisMik
DennisMik's Avatar
Maybe yes, maybe no. If you were cruising at high engine rpms, the odds are good for a yes. If you were just idling, you just might get away with some valves and pistons. You have to open up the engine and see what's what in there.
The price will vary on who is doing the work. A replacement engine at a lexus dealer is something like $6K. A used engine that you put in yourself could be between $1000 and $1500. If the work is done by an independent mechanic, the price will be somewhere in between. If the engine can be repaired, it will be a lot less than replacing the engine. You need to find out how bad it is.
Old 10-03-17, 08:24 PM
ukrkoz
ukrkoz's Avatar
So much for lifetime warranty? I'd go to dealer first and sternly inquire how is life time chain influencing cost of repairs.
You need to find out if your engine is interference or not. If it is, it is kaput. Not worth rebuilding. If it's not, you take chance that it will be fine after belt replacement.
That's good lesson for those who think that chain is indestructible. Actually, those chains suck. Very long, very narrow for the job. They stretch and stretch quite a bit. Ill designed tensioner does not help. Run engine low on oil few times, and voila.
Old 10-03-17, 09:10 PM
tomr51
tomr51's Avatar
how many miles on the engine? was the engine oil level ok? this is not a common fault.
Old 10-06-17, 06:00 AM
05RX330AWD
05RX330AWD's Avatar
Unusual for this to happen, definitely some engine damage.
Many debate RX330 or RX350, timing chain or timing belt, at least the timing belt has a maintenance schedule....
as far as lifetime service for a timing chain, unfortunately here's proof that nothing lasts forever.
I would take that up with Lexus Customer Service, hopefully they can approve a Goodwill Repair.
Old 10-06-17, 09:33 AM
DennisMik
DennisMik's Avatar
That's for sure. If it is made by man, that's a guarantee that it will fail.
Old 10-06-17, 10:24 AM
Drizell
Drizell's Avatar
When it comes to that, its a Big Fix. If Lexus can replace the chain or help with good will cost then okay. If not I would persue alittle Xtra Store credit with the Lexus dealership. They would be happy to adjust the price of a Newer model since yours went through an incident. They would rather keep your business. I wouldent take the car to Independent shop for re-build. Nah too mayn options out there to waste time with greace monkey.
Old 10-06-17, 10:36 AM
pauljcl
pauljcl's Avatar
FWIW: A friend in France had (still has) a then-12 yr old Mercedes with only about 65K miles. The timing chain broke. He had it trucked to Mercedes dealer, who contacted Germany and they replaced his engine 'free' - it took six weeks (!) but they provided a loaner vehicule. Mercedes simply said "That is not supposed to happen". Maybe Lexus will have a similar attitude - certainly worth speaking to Lexus through your dealer and also directly.
Old 10-06-17, 09:06 PM
5W40
5W40's Avatar
Originally Posted by kitabel
How do you know it's broken?
Yes, my first thought is plastic guide broken.
OneGuyInCA
RX - 1st Gen (1999-2003)
27
10-21-19 10:47 PM
guptaab
09-11-11 05:33 AM
roller400
11-07-07 10:41 PM
Max707
Maintenance
08-28-06 04:33 PM
splinter
Maintenance
04-07-03 03:33 PM
Quick Reply: timing chain broke
