2007 RX350 Center Console Extra Switch
Old 10-11-17 | 10:33 AM
FJ40RX350's Avatar
FJ40RX350
Default 2007 RX350 Center Console Extra Switch
2007 RX350 I have a center console panel between the decorative gearshift surround and the radio. It has (L to R):
1. Two Heated Seat Controls
2. Headlight Spray Switch.
3. Cigarette Lighter.
When i remove this panel, on the back, there is clearly the support for another switch between the Headlight Spray Switch (unplugged in picture) and the Cigarette Lighter (black arrow). Also, on the wiring harness going to the cigarette lighter is another (unused) two-wire connector that i assume goes to whatever option this missing switch would be for (white arrow).
1- Does anyone know what option this switch space is for?
2- Does anyone know the specifics of that two-wire connector (e.g. amperage rating & which fuse it goes through)?
3- Would cutting the panel from behind to put in a custom accessory switch using an OEM standard Toyota Push Switch be easy, or should i just buy a new panel with all the holes already made? If so, what would be the part number? I cannot find a picture of a 4-hole version of this panel.
Attached Thumbnails 2007 RX350 Center Console Extra Switch-panel-switch-q.jpg
Old 10-11-17 | 12:44 PM
Lexuswiz's Avatar
Lexuswiz
1. Its supposed to be the air suspension switch where you can adjust it up or down (the control lights would be on the speedo gauge).
2. No idea
3. Cutting may be hard but I've drilled into the open area to put a USB port for my GROM unit.
Old 10-11-17 | 02:27 PM
kitlz's Avatar
kitlz
No, I don't play soccer!
Here's a picture of the panel with the air suspension button.
Just outside the picture in the upper left is a power button added by an installer to control an amp. The red light indicates power on. So it's possible to add a switch to the panel.
mcomer (10-11-17)
Old 10-12-17 | 03:11 AM
05RX330AWD's Avatar
05RX330AWD
Agree with the above, although for installing the switch, I would recommend using a quality utility knife with a new blade to make the hole for the switch.
Replace the blade with another new one after cutting part of the area if needed be. Patience is the key, some plastics are difficult to cut.
Installed a switch on a Equinox which most likely had the same type of plastic, it took awhile although the switch snapped in perfectly.
Old 10-12-17 | 08:28 PM
DennisMik's Avatar
DennisMik
I was looking up part numbers on the panel. You probably don't want to buy one as the dealer price is $580 +
There are 11 different part numbers - 1 is discontinued, 3 don't have wood trim (those are only $60). Of the 7 left, I can't figure out which one is really the one you want.
Here is the list:
55432-0E010 $59.72
Part Name Code: 55432B
Panel, Instrument Panel Finish, Lower
CANADA SPEC&SPORT PACKAGE&STEERING WHEEL-LEATHER&SEAT HEATER-WITH,TYPE A:REFER ILLUST.
CANADA SPEC&SPORT PACKAGE&STEERING WHEEL-LEATHER&SEAT HEARTER-WITH,TYPE A:REFER ILLUST.
Fitting Vehicle Options:
MCU3#.. NAP; GSU3#.. NAP
55432-0E020 $59.72
CANADA SPEC&SPORT PACKAGE&STEERING WHEEL-LEATHER,TYPE B:REFER ILLUST.
55432-0E030 $59.72
SPORT PACKAGE&STEERING WHEEL-LEATHER,TYPE C:REFER ILLUST.
55432-0E100-E0 $678.56
CANADA SPEC,MD.BROWN,TRIM11,15,2#,TYPE D:REFER ILLUST.
MCU3#.. NAP
55432-0E100-E1 $678.56
CANADA SPEC,LIGHTBROWN,TRIM00,01,TYPE D:REFER ILLUST.
MCU3#.. NAP
55432-0E110-B0 $577.00
CANADA SPEC&SEAT HEARTER-WITH,DK.GRAY,TRIM12,TYPE E:REFER ILLUST.
GSU3#.. NAP
55432-0E110-E0 $577.00
CANADA SPEC&SEAT HEATER-WITH,MD.BROWN,TRIM11,15,2#,TYPE E:REFER ILLUST.
CANADA SPEC&SEAT HEARTER-WITH,MD.BROWN,TRIM01,11,2#,TYPE E:REFER ILLUST.
55432-0E110-E1 $577.00
CANADA SPEC&SEAT HEATER-WITH,LIGHTBROWN,TRIM00,01,TYPE E:REFER ILLUST.
CANADA SPEC&SEAT HEARTER-WITH,LIGHTBROWN,TRIM00,TYPE E:REFER ILLUST.
55432-0E120-B0 Discontinued
DK.GRAY,TRIM12,TYPE F:REFER ILLUST.
GSU3#.. NAP
55432-0E120-E0 $577.00
MD.BROWN,TRIM11,15,2#,TYPE F:REFER ILLUST.
MD.BROWN,TRIM01,11,22,TYPE F:REFER ILLUST.
55432-0E120-E1 $577.00
LIGHTBROWN,TRIM00,01,TYPE F:REFER ILLUST.
LIGHTBROWN,TRIM00,TYPE F:REFER ILLUST.
Fcesar56
ES - 5th Gen (2007-2012)
05-01-19 10:01 PM
mdv
09-23-14 08:12 PM
HokieCJ7
12-13-12 02:36 AM
KKRlexus
11-12-08 08:06 PM
