RX 400h interior lights and vanity light wont turn on?
Hello,
The lights to the vanity mirror on both driver's and passenger's side, the dome light, and the dome light in the back wont turn on. Can it be a fuse problem if the navigation, clock, and gauges/meters are working fine? I dont know what the problem is, but if it was a blown fuse I thought all those systems wont work since its the same fuse#. Thanks for your help!
All the lights you mentioned (and some you haven't) are powered by the same fuse, so it is likely that the fuse is blown. Other things, such as the clock and gauges, get their power from other fuses not the lighting fuse.
Check the 7.5 amp fuse labeled "DOME" located under the hood on the driver's side next to the fender.
fbrown1
GX - 1st Gen (2003-2009)
02-25-14 11:19 AM
