Rattle on 08 rx 350 120k
This is probably a rhetorical topic: regarding the cold start up rattle for about 2 seconds then quiets down . Its getting a little more annoying I had put synthetic 5-30 in it about a month ago. can't seem to get any definitive answers on whats causing this and how to repair or forget this as some mechanics have indicated that it won't harm the engine.
I am concerned about the long term duration of this problem. REX has 120k and runs great good power , shifts good. Different opinions about it.
I am sure other forum members have had this problem so......any suggestions Would appreciate any ideas.Thanks for response.
08 rx 350 cold start
Thank you Tomr51, My mechanic alson advise not to worry, but it was getting steadly worse. My question is there a remedy for this start up
I am trying to understand the function behind the oil draining down into oil pan and not staying up to lubricate a cold start. Is this the desine of the engine
or a malfuntion of the engine. Someone had suggested an additive such as Bartol 1 or somethinglike that so upper engine would not rattle on cold start up.
Anyother ideas out there or is everyone in agrrement about gthe problem . Iam Lexus is aware of it , but do they have a simple solution. Thanks
