change wheels on lexus rx350 2gen
hi guys. looking to change wheels.. does anyone fitted wheels from Porsche or audi 5x130 whats the maximum width that will fit and dosent stick out from the arches?
thanks
zar
thanks
zar
The RX wheel uses a bolt pattern of 5 x 114.3 mm with a hub opening of 60.1 mm.
The Porsche/Audi uses a bolt pattern of 5 x 130 mm with a hub opening of 71.3 mm.
The different bolt pattern will not allow you to use these rims.
Hi. Thanks.for reply. I have seen some pcd 20mm spacers which will convert it to 5x130 and porsche CB.lots of this.on ebay..
An adaptor would certainly let you bolt on the Porsche/Audi rim. But the 20mm thickness would push the tires out towards the fender more.If you use a bigger (wider) tire, that will bring the tire closed to the fender. For reference, the stock 18 inch Lexus rim uses an offset of 35. I don't know what the Porsche/Audi rim offset is.
Overall, I don't know if you would have any issues with the tire rubbing on the fender or anywhere else. Hopefully someone else will answer your questions.
Thanks for quick respond... Hmm.. So.if i would change them to 20" with 35et whats the thicknes 9j would.fit with 45mm tyre or 8,5j ?
thanks
zar
thanks
zar
Hi. I just bought set of 22" 9.5j wheels with offset +30 (et30). Just wonder if would fit without any problems. Wheels are in garage for respray currently. Tyres on them 265/35/
Do i need any spacers for front or back... ???
regards
regards
KyleC
05-09-02 06:11 AM
enginyr
Wheels, Tires & Brakes Forum
40
04-01-02 08:52 AM
