New Battery installed- Electronic issues
Old 12-17-17 | 11:55 AM
mreinhard's Avatar
mreinhard
Default New Battery installed- Electronic issues
The day I had battery installed by Auto Zone, my windows quit working. Took it back and they told me drivers side window switch is bad. But I have researched and have seen that it could be something else. Please help!
Old 12-17-17 | 12:15 PM
smassey321's Avatar
smassey321
https://www.clublexus.com/forums/rx-...what-else.html
NVAKeith (12-17-17)
Old 12-17-17 | 06:33 PM
2for1's Avatar
2for1
This is normal. There's a sticker in the engine bay that informs you. Takes a couple days and they start working. Odd
Old 12-18-17 | 09:24 AM
mandyfig's Avatar
mandyfig
Did you re-set your windows after the battery change? If they were working prior to the battery replacement, they should work after.
Old 12-19-17 | 01:04 PM
seahamcw's Avatar
seahamcw
Default Battery change.
You need to take it to lexus dealership to have all settings on car reset
Old 12-19-17 | 01:05 PM
seahamcw's Avatar
seahamcw
Need to have all settings reprogrammed by lexus or your fuel costs will rise too
Old 12-19-17 | 02:08 PM
LOLjasonW's Avatar
LOLjasonW
I replaced my battery on my 3gs and had same problem sunroof and windows would not auto roll up or down. On my car I had to go to each window individually roll window all the way down and hold it down for 3 seconds then roll the window all the up and hold for 3 seconds. After each window, test to see if it auto rolls with the button. If it doesn't work, open the door and close the door, then start rolling window all the way down/up until it sets. Same thing with moon roof. This should set it, well it did on mine I hope it helps yours
dantampa
06-15-15 03:58 PM
kickin8
03-03-14 09:27 AM
heab0774
GX - 1st Gen (2003-2009)
11-05-11 10:17 AM
pamada
11-02-11 04:13 PM
mcnelson
02-23-03 12:27 PM
