2007 RX Sunroof, Center Console Lights, Compass inop
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Greetings all! I hope someone can assist. It appears my Sunroof, Courtesy Lights, Dome Lights, Mirror Compass and Center Console Lights are not working. In regard to the Center Console, the radio and A/C are working properly and have illumination. All other buttons (i.e. fan, temp, hazards, defrost, etc) are all working properly, but no illumination. I checked both fuse boxes under the dash and hood. All the fuses are good. I'm stumped. Any suggestions before I head to the dealership...? TIA, DP
DPNOLE92 (02-04-18)
Hey Lexuswiz. Appreciate your help. So I pulled the overhead console down. Checked for power to the sunroof and checked for power to the overhead console (map lights assembly). Both had power, so I ordered another overhead console from eBay. It arrived, I plugged it in and got the same result. No dome lights, no sunroof, no compass, no center dash illumination. Was the second overhead console bad too? Possible. I'm off to check fuses again. Appreciate ya! - DP
RX 330/400h Anyone knows how to remove the transmission selector console to change the bulb, without breaking anything?
Hi DP
I have the same exact issue. Did you find a solution. Does that have a fuse that I can't locate? I just had some work done on the AC and it required taking out dash (big job), That mechanic is far from me so i was hoping it was just a fuse i could switch out.
Thanks!
Thanks!
