Should I be concerned over this damage?
Two days ago, I went to a reputable shop in the Bay Area recommended by the CL forum for an oil change, however...this morning when I was walking to the car, I noticed something unusual underneath the car. I thought it was odd to have something sticking out that low, so I got down to discovered a piece of wood stuck at where the point of contact that a jack-stand would be.
I am unsure if this is caused by the technician at the shop leaving a piece of wood on the rack prior to lifting my car up for an oil change, or if this is something sinister caused by a stranger. I have parked my car at my University's parking garage - so I think it is fairly unlikely this would happen.
What exactly is the damage of this? Is this the frame of the car or something else? Should this be fixed and should the shop be responsible for the damage? How much would the repair be, and what would need to be replaced...or is this something a shop can knock it back in place?
Imgur pictures:
https://imgur.com/a/6wmyD
Imgur pictures:
It looks that the guys use this black to protect under the car,the damaged area may be from before,I have my car the same,,if you want an added protection you can spray the area with the undercoat or brush some liquid asphalt
I am more concern about whether this jack point can be used in the future (ie. having a flat and need to change the tire)
I am surprise that not a single technician have brought it up that the jack points were bent
My mechanic uses the same trick, although the wood would be used inverse to your picture with it stuck to the pinch weld, the "cut-out" of the wood should be where the pinch weld is not the opposite..... I assume your car was put into the air on a 4 leg lift which they forgot to remove the foot when done. Judging by the way the wood is used in your pic, I would say it could damage the pinch weld although I will not say for sure as it could have been damaged prior.
As for your question on usability, it still can be used as a jack point with a normal jack but a scissor jack will probably not work as it relies on that pinch weld to fit into the slot of the scissor jack. Definitely take your scissor jack out and test it.
Thank you so much of letting me know that its called a pinch weld!
Im doubt I'd be able to use a scissor jack until that spot is angled back to its original position
Also: glad that piece of wood stuck onto the pinch weld, it would have be a disaster for it to fall off while cruising at 70 mph on the interstate
Okay, so I guess it is common for mechanics to use the wood in order to support and maybe alleviate the point of contact on their lift equipment? The car was definitely put in the air, but should the block be in a position where it sits flat to the jack points? I noticed the cut-out of the wood, and knew that it definitely belonged into a car shop...
I wouldn't say common but if their lifts are old (my mechanic is an old school guy), odds are it has a large circular plate at the ends of the lift arms are instead of a specialized piece that will allow a pinch weld fit snug into it, the wood trick is so it fits the small slot of pinch welds as the disk is rather large. And this is because if you lift by the pinch welds, the whole underside of the car is in your sight, you don't have the lift interfering with the subframe and what not which would be an issue with the front and rear jack points which are dead smack in the middle of the front and rear of the car.
How do you know the pinch weld wasn't bent already?
Maybe that's why they used the wood-to even out the level.
Ive also asked whether the wood block came from their shop :/
For something like leaving this on a customer car makes it uneasy for me to think that they will be the same shop that I'll do future maintenance on
time to find a new shop if anyone lives in the Bay Area can point me to another one
I had an alignment done before, and I'm not sure how the alignment system work - but I would assume that they have to rack it up on the system and it has to be completely flat before adjusting chambers/toes/other stuff?
Yes, i think with that comment , it's clear you don't understand alignments. You don't hang a body when doing an alignment, it sits flat on a table.All i was implying was that if it gets lifted a on a two post hoist it is possible that the sides or posts are not level with each other and the wood acts as a 'shim' to even the sides(posts).I doubt very much that the garage bent the weld. I think someone went over a curb or something hard and it 'bottomed out' on that piece, whether that was you ,a family member, the garage or the previous owner(s) but i have NEVER seen a two post hoist do that and i doubt i ever will.I would think the wood got hung up when they lowered the hoist and because it's never happened before they didn't think to check for the block.Good shops are hard to come by. I would think twice, if they are good, before you cut them free or give them too much grief.
lunatyk
CL of Southern California
05-06-11 10:41 PM
