Key
I have purchased both the OEM $50 key and the $10 Denso one. The Denso was better than I expected. The plastic quality and look is identical. The Lexus logo is slightly different but other than that they are the same.
https://www.ebay.com/itm/Lexus-3-But...Y/232611734468
Instant Keys in Jacksonville cut mine for $20 each. They prefer to use the old key rather than just the code. They use the old key to determine the code which eliminates the chance of error. They were the only shop in town that can cut from a code. Call around to find the shop that can cut using the code. I did not want the old key used as it was worn down.
I've used these guys before...You can get the key cut based on keycode or you can send them a picture of the current key and they cut and send to you. I used the photo option before and no issues with the cut key or the quality. They were fast and turnaround was less than 2 days.
http://www.ebay.com/itm/PRE-CUT-3-BUTTON-REMOTE-FOB-KEY-EASY-DIY-PROGRAM-KEYS-for-MODELS-w-4D-CHIP-/162556390578
