How do I get access to ECU?
What exactly are you trying to do? Do you need to remove it completely or just tap a few wires? If you need to tap, then removing just the glove box itself should allow good access, I did this while tapping the tachometer for my remote start. But if it needs to come out, you'll have to remove the lower dash, I recall it comes apart with a few screws and bolts once the bottom cover and kickpanel are out.
Thanks so much for the pictures of the removal!!!
Made it easy. I have mine out and the action of the screwdriver to remove the top three interfering connector housings is still somewhat of a mystery, but I got them out. Whether the screwdriver is pulled away from the connector or pushed back toward the connector, I am not sure, but you are correct about the slot you put the screwdriver in.
pishta
05-22-16 02:55 PM
