control arm question
Hello everbody
I am a new member of this forum. I have one question since i can not find really useful information on this topic. I need some new control arms for my rx 330. But which one would you recommend? I've seen a couple ones on rockauto. I would like to buy some moog control arms but of course there is no information wheter they fit in my air suspension rx. all other control arms on rockauto have this information ( at least the ones i don't want). The next problem is that there are two different moog control arms. One costs like 50 bucks and the other is 80. Is there a difference? They have different part numbers thats for sure. Please help. I want to buy something thats decent quality, so i don't have to change them in like one year again.
Greetings
Greetings
You NEVER know what you get from online order. This is slippery road esp for unique vehicle with air suspension.
I'd recommend using a local store and matching part to part. At least, it's easy return. Yes, costs a bit more but much less hassle.
Hello everbody ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Greetings![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Greetings
Not only are the Toyota/Lexus OEM parts high quality (as good as or better than most aftermarket), but doing so ensures that the parts will fit on your vehicle.
This is every important especially if you are having someone else (your mechanic) replacing or fixing the component.
In the grand scheme of things, the hourly cost of having a mechanic dwarfs the higher cost of an OEM part.
Isn't there any good alternative to OEM ? They cost 250$ each
I even wrote a e mail to moog two days ago... Nobody replied since then![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
I am dping all work on the cars myself, but i've read you have to jack up the engine to take out the control arms, so i want something of rather good quality to save myself a lot of hassle. If there is no other alternative you can recommend, well than I have to rob my piggy bank and go for oem
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Moog offers the control arms with and without the ball joint on it. This is probably the difference in the price you are asking about.
I would suggest that you also get new bushings to go with the arms.
Apperently , they both have a balljoint, but somehow, one is like half the price of the other. I searched moog's webside again and found some contact formulars which I then used. Now I am waitig for an answer... I guess we will see. Reviews of those conrtol arms are still appreciated. If anybody here has made either good or bad experiences , feel free to write it down
OK, I have replaced these with aftermarket (Moog) on my RX400h. Part of my redo on the suspension. They fit fine, and the biggest issue is getting the one vertical bolt out under the Motor mount area. I followed the jack the engine carefully under the oil pan and was successful. This is one of those jobs which takes a fairly good mechanical knowledge. On a scale of 1 to 10 I would say a 9 in the scale being difficult. You have to be very careful with the drive shafts when taking everything apart. After market? Yea fine. Quality seemed great and I have had no issues. I ordered from RockAuto. Good luck ps suggest with ball joints as you are already replacing a major portion of the suspension.
No ball joint is more expensive than with ball joint. That's crazy! The control arm part is the same. Get the one with the ball joint and it will make the repair a little faster and easier.
Yes I used the one with ball joint. I have about 40k miles on them and have experienced no issues. No my car did not have air suspension. Had traditional struts with springs...
