Window stuck in down position
Hot day...rolled down the windows...detached battery. Upon reconnection, the windows don't work. Went to manual - tried reset; BUT...the windows are already down, so I can't "roll widows down half-way" (the first step of reset).
I am stuck with windows in the down position. Only driver window works.
How can I 'reset' when the windows are already down?
Thank you,
Rico
Thank you,
Rico
Yes - in fact it is in the manual....I just pulled a lamer...forgot to check 'window lock' - which was set to lock. Kinda hinders the reset process. Oooff. Problem solved.
shortbus19
12-20-11 09:25 AM
