Ignition cylinder replacement cost
Cylinder? Or, "ignition cylinder", which is actually an ignition pack? I bought them aftermarket for around $70 and they work just fine. Now, the front ones are maybe 10 minute job each. The REAR ones are different, you need to either be a Houdini type magician with your hands or remove cowl and some other parts to get to them, so it costs much more. I'd say, indi mechanic will charge you around $300 to get one of them replaced plus your part.
Hi all,
My problem is that when I remove the key from the ignition, the courtesy lights, radio, and lighters still are on and intermittently. Can somebody give me advice,
I think I am going to replace the ignition switch, my concern is if when I remove the 2 scrolls come up like one piece or have any joins or something that make it more complicated.
Thanks to all of you.
Kind Regards,
Kind Regards,
mhsu408
04-25-06 10:29 PM
