Japan AFR sensor installed in a Canadian built RX
So a code came up indicating my AFR sensor has failed in my Canadian built 2007 RX 350. It turns out the sensor for a Canadian build is substantially more expensive that a AFR sensor for a Japan built RX.
So I went with the Japan build for about $100 cheaper...it seems to be working just fine (have about 10K since changing sensor) with no codes coming up.
Is this a money grab?
gvse
05-07-14 06:48 AM
