front wheel hubs & bearing? or just quality bearings?
Hello folks,
Any reason we need to replace the wheel hub? Do they go bad? I understand if it was an assembly, make sense to replace the whole thing but for the RX330 FWD, bearing need to be pressed out/in. I wonder I should invest in getting higher quality bearings rather then spend on the wheel hub kit.
Why do the hubs need replacing?
Difficulty in getting the old bearing race off is the only reason to replace the hub. Replacing the strut if removing the old bearing is too difficult or the strut is damaged.
Are you a DIYer? If you do most of your work yourself, then I would invest in good bearings and tools. I use the OTC Hub Grappler to remove the wheel hub. You can buy the Grappler by itself on Amazon for $140.00
Thanks Audiqv8 for your tip. I will do my own replacement. I was leaning toward getting 6 ton press from Harbor but final decision was to take the risk with
Will borrow 30mm socket, hub puller from autozone.
I hope to have a better luck then the dude in the video. I'll have penetrating oil and torch ready. I'm just replacing the bearing, going with Timkin.
This is financial and safety decision.
Variable 1: cost of the entire new hub assembly + time to replace it + cost of tools. No matter if it is DIY or taken to shop, time is worth what it is worth.
Variable 2: cost of new bearing+time to replace it+cost of tool necessary to do the job x possibility of something not going right when DIY.
Variable 2 has sub variables:
- rent tool
- take removed hub to a nearest shop that has press, pay nominal amount, usually around $10-20, to have it done by their staff. In this case, "x DIY going wrong": coefficient is significantly less. Also, this involves subvariable: - ownership or rental of tools that are required to remove hub+vehicle to take to shop+ know how and skill+time to do this
- buy tool that will be used basically once then becomes depreciating item on the shelf.
There is another hypothetical yet very significant consideration.
It is a hub. Hub bears entire that end vehicle weight on it. Vehicle carries passengers. Kinetic energy is K.E. = 1/2 m v2 .
- rent tool
I just did this. See my recent post: 2007 RX350 Front wheel bearings DIY. I replaced the entire steering knuckle assembly. But I live in a super expensive area so you can probably take off your steering knuckles and take them to your local shop to press off old bearings, grind off the races, press in new bearings and voila. I highlighted the steps if you reuse your steering knuckles because there really isn't a need to replace them unless they are damaged. Or you live in Kailua-Kona where shops are INSANELY expensive. Like, outer worldly expensive.
For reference, a loaf a bread (not on sale) at the grocery store costs $8.00. Yes, US dollars. Good luck !
1WILLY1
08-18-16 05:25 PM
