RX 330 Performance Package with Nav questions
Just picked up my RX 330 Silver/Black with Performace and Nav last night. I've only driven it 3 miles so far however I have some questions.
1-When the height selector is set to N is that the automatic mode? If not how do I set it to automatic?
2-Do I have to keep pushing in the Easy Access button each time I start the car or does it stay on?
3-I don't mind the voice with the navigation however the beep is going to drive me crazy any way to turn it off and still have the voice?
Thanks in advance
Alan
PS If anyone is waiting for a similar equiped model I cancelled a Flint mica when the Silver came available. Let me know and I can give you more info.
Thanks in advance
Alan
1) N is automatic - car will lower slightly at 62mph
2) my easy access button stays on until I turn it off
3) there's no way to isolate the sounds on the nav - the only way to mute the sound on the Nav is to go to lower the volume all the way
Thanks in advance
Alan
Thanks in advance
Alan
Which Dealership did you use and did you get at least some kind of discount off MSRP?
Lexguynj, I leased from Lawrence Lexus however Ray Catena had a car in Flint Mica that was coming in at the end of the month that I cancelled. Ray Catena told me it was MSRP but inorder to get my monthly payments where I wanted them Lawrence had to discount the car.
Alan
Alan
Alan
Alan
I got lucky. I went to see what Flint Mica looked like and saw a Silver, went inside snd asked the salesmen (who 3 days earlier told me I would have to wait a few months) about the car on the lot and was told a deal fell through. That was Friday. Picked up my car Wednesday night.
You're not going to get much more than $1000 off in this area. The car is hot.
Alan
Alan
Alan
Alan
Can anyone tell me the benefit of Performace Package on RX330? What will be the driving experience of High or Low suspension? Do you think it worths the buy?
Thanks!!!
Thanks!!!
Thanks!!!
Thanks!!!
the low suspension mode allows you to take the curves faster on winding country roads or even off/on ramps. The suspension stiffens up a bit plus the lower center of gravity helps. The high suspension is for off road use, to give more ground clearance. I used it the other day when I noticed the street ahead was flooded with well over a foot of water in the road. Put my suspension in high and went through it, literally high and dry. Cars that plowed through took on water in the passenger compartment.
I do think that that the regular suspension will be okay for most drivers unless you like to drive more aggressively and fast. I pretty much leave my suspension in normal now. Everytime you turn the RX on, it defaults to normal, so it became a pain to keep putting it low mode for driving around town and to work.
