center console: piece of metal .. ?
hello :-) i just bought an '09 RX350 & found something interesting in the center console ... the "tray" (that slides the length of the console, but does NOT lift out) has an interesting indentation with a metal piece... on the side, near the bottom ... anyone know what that is?
mystery removable clear plastic piece under center console
(disregard the water spots on the clear plastic piece, i had just washed it)
Yes, the manual described that tray on page 131. It says "To remove the adapter tray inside the box, pull it up."
It has no additional reference to that tray. That clear plastic thing under the bottom is interesting. It appears that it is some sort of tool. Otherwise, why go through the trouble of manufacturing it? If you remove it, does the tray still sit inside the console box properly ?
carieking (08-31-18)
yes it does
ok, so a tool for what?! ... hopefully not an emergency, bc it's quite an ordeal to get to it *lol*
That clear plastic is to refract the LED light through the tray in the center console. At night you can see it working. It's a pretty neat little detail.
thanks Carfan!! (how'd you know / find out this info?!)
Carie
