RX330 front brake rotor removal
Hi all, there are 2 threaded holes on the rotor to aid in removing it... someone once said use a M8 bolt.
Anybody know the length and is there a width or is M8 a standard width??
Thanks!
Thanks!
It needs to be more than an inch for sure but since it's metric say 50mm. M8 will have the diameter of 8mm.
I don't even bother, if I have the new rotors on hand and ready to install, a metal mallet from the back will free the old rusted-on rotors. Just put one lug nut so the rotor doesn't go flying off the hub and landing on you or your foot.
sbrown329 (09-14-18)
Lexuswiz (09-15-18)
That "removal" hole is joke from Japanese engineers. You have about 1.5 thread in it. Do you really think it will do anything for a rusted on rotor? As I tried, you know.
I don't hammer on rotor braking surface. i found that few hard hits between the studs, on rotor hat, do trick very well. Just needs to be aimed well not to hit studs.
I wire brush the rust off of the center hub then spray PB Blaster around the hub, around each stud and in the those bolt holes. I don't always need to use a hammer when I do this.
tonydt1g3r
01-19-07 12:41 AM
