Tune up for Lexus RX 350 due when?
First off, welcome to Clublexus.
This is good reading, enjoy your RX.
https://www.clublexus.com/forums/rx-...ate-links.html
Enform isn’t that great. They’ve removed 3 or 4 apps and not replaced the older units. Knowing how Toyota is. I’d love to find a totaled 2020 when it happens and swap the 12” monitor with the touch unit. If you look closely the dash is still the same. They just added a new trim plate relocating the monitor closer to you.
When it hits 120K miles, it will be a major one.
Just had it done on my wife's 08 RX350 AWD at 133K miles. 6 spark plugs, 3 rear coils, valve cover gaskets, manifold gaskets, power steering fluid replaced.
Also had the transmission fluid drain/refill and transmission filter / gaskets replaced at ~120Ku miles.
Guys, I just ordered a Canadian base model (now called premium) which is white with Noble Brown leather interior. Confirmed with the dealer that it was not Nuluxe.
Curated Content Editor
RX - 4th Gen (2016-2022)
09-13-19 08:07 AM
