2007 RX350 Squeaky rear
10th Gear
Car: 2007 RX350 with 102,000 miles. Well cared for car in general.
Issue: Getting some squeaking noise from the rear of the car. You hear it mostly when going over bumps (think those speed bumps) and when turning right or left. Noise is squeaky and 99% sure it comes from the rear of the car. Suspension? Spare tire is loose?
I suspect it needs some suspension work now that we have passed the 100,000 mile mark. If that's true, what kind of money am I look at here to get fixed up (dealer vs non-dealer)? Given the car is well cared for, I would probably look at doing all four corners of the car for suspension, but would value opinions.
Check the rear sway bar bushings,mine went bad and it was doing like that,replaced and quiet again,you can look at it from the rear of the under the car toward inside of the wheels
JShort
Suspension
12-26-12 04:14 PM
