Rear wiper does not work.
11-21-18, 06:07 PM
Need help with rear wiper. Didn't work, changed the motor, still doesn't work. Any help will be appreciated.
11-21-18, 06:28 PM
Did you check/replace the fuse? It is in the under dash fuse panel. It is named RR WIP and is about in the middle of the row.
11-22-18, 06:00 AM
Checked the fuse it is good.
11-22-18, 07:39 AM
Do you get power to the motor? There are fusible links in the harness. Will it operate when directly jumped from 12V?
11-23-18, 06:02 AM
Yes it does operate when directly jumped from 12 volt.
11-23-18, 07:36 AM
Ok, but DO YOU HAVE POWER TO IT WHEN TURNED ON FROM THE SWITCH? It can be harness fusible link, it can be switch itself.
11-24-18, 11:16 AM
Yes, he said it does have power from the switch. He said it is hot all of the time when the key is on.
11-26-18, 12:06 PM
So is this a 3rd party on which you are trying to debug the rear wiper issue on?
Scotty15
07-10-17 06:00 PM
RgSc
SC- 1st Gen (1992-2000)
07-14-12 08:40 PM
Suddog
03-28-10 12:14 PM
superfreak
Maintenance
10-12-05 07:36 AM
