Dual Exhaust on 04 RX330
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Hi from the Land Down Under,
I have just come back from my exhaust shop and my guy tells me that he will have no problems with installing a dual system.
He plans to adapt to the bottom cat converter and run a single pipe to about half way under the chassis, making a kind of "s" type muffler branching out into a split system with a small resonator on each side. He has access to a plastic fabricator that will cut the plastic bar to accommodate the tailpipe so that it looks standard.
The pipework is all mandrel bent, in 2.5" polished stainless steel including the custom mufflers.
Price is expected to be around $A2500.00 and fully flanged etc so that it appears stock. Will hopefully have this work completed by October 10th and will post pic's of the job as it progresses. Stay tunes for pic's and commentary on how it looks and sounds.
RX 300 & 350Z Guru
Originally posted by jeffknet
hey at least it ain't an MDX with the dual exhaust both on the SAME side
![](https://www.clublexus.com/gallery/data/500/1072004_MDX_Rear.jpg)
CamRen
02-19-02 01:06 PM
