What color wire is daytime running lights?
There is no separate wire that is dedicated to the DRL. DRL is created by sending 6 volts (?) to the lamp instead of 12 volts. You will have to tap into a wire that has voltage only when the car is on. I don't know if there would be a way to make your aftermarket DRLs go off when the headlights are turned on without adding additional components.
CCJ22
08-26-11 07:46 AM
