2004 Rx 330 Struts and radio replacement!
Ok gang!
New to the forum! Two questions. I need to replace front strut assemblies and based on a quick search KYB is popular, any feedback on these or others? Has anyone used duralast?
Also, thinking about replacing the radio to an apple carplay compatible model. Also looking for recommendations!
Thanks in advance!
J
Thanks in advance!
J
https://www.clublexus.com/forums/rx-...l#post10476261
https://www.clublexus.com/forums/rx-...l#post10480635
schwartzPT (05-15-19)
I haven't replaced any struts on a Lexus, but I had great results replacing all the struts on a 1997 Maxima with Monroe QuickStruts. Restored the ride height, the ride quality, everything felt perfect. YMMV but I'll go that route when my RX needs it.
The following 2 users liked this post by RX350LB:
schwartzPT (05-15-19),
ukrkoz (05-16-19)
Like RX350LB, I have not replaced the struts on my Lexus yet. And like RX350LB, I did replaced struts on my 1997 Maxima that I had and used KYB struts. The KYB struts were stiffer than the stock and the car rode rougher. Handled better, but I wasn't happy with the rough ride.
Do a search on Carplay here, and you'll find numerous thoughts and experiences. I opted for a Pioneer MVH-2400NEX, replacement of the terrible stock amp, and replacement of all speakers. There were a number of headaches along the way, but the end results are fantastic.
Be sure to view this complete video tutorial as well -- there are some handy wiring guides and time-savers in here.
For me, ultimately, the Axxess TYTO-01 amp interface was garbage. I stripped it apart, saving only the wiring harness, and threw away the rest.
After I replace my right-side leaking rack and pinion in a week or so (55,000 miles on the 08 RX), I want to turn my attention to exactly these issues. I installed a Kenwood DNX575S head unit and am terribly disappointed in the sound. I figure a $600 receiver should potentially sound a lot better than what I'm hearing.
RX350LB, I went with an Alpine MRV-F300, for the incredibly clean Alpine sound that I love, the good price, and that its physical form is functionally pretty close to that of the original amp. And yes, I put it in the stock amp location, reusing the original mounting brackets with some minor spacing adjustments. My detailed write-up with photos is here: https://www.clublexus.com/forums/rx-...l#post10458406
For speakers, I went with Kicker CS-series at all eight points. I probably would have gone with Polks, but Kicker had a better match to the sizes of the stock speakers in all locations. They're a bit brash, but that actually fits my middle-age high-frequency hearing loss quite nicely. Bass sounds good but feels unimpressive, so the next upgrade is a Kicker 8" Hideaway powered sub... once I figure out where I'm going to run the positive power lead through.
I did run new line-level outputs back to the amp, then re-used the stock speaker wires (16 ga.?) from there. Audiophiles would object, but I don't believe my ears would discern enough difference to be worth the effort to run all new speaker wires.
Ultimately, I think my initial poor sound with the Pioneer but just the stock amp was due to three things:
1.) The Axxess TYTO-01 is a somewhat half-assed piece of equipment. Almost 20% of the online reviews I read had the same issues with it that I did.
2.) The stock amp is calibrated to drive 2-ohm speakers, and the Kickers are all 4-ohm.
3.) The Axxess TYTO-01 is designed to pass speaker-level output to the stock amp.
KMB (05-22-19)
So I went and purchased the Alpine S-A32F, which is the slightly newer model of the Alpine MRV-F300 amp you specified. Thank you so much for the suggestion. Saved me a ton of research and guesswork.
So for the A-pillar tweeter you replaced with a Kicker CS that fit pretty well?
I've read other users' comments that 1" tweeters will also fit, but the 1" ones cost almost twice as much, and my budget was harsh and unforgiving.
Now, the tricky thing is...
Two pairs of wires come up out of the dash to feed the Tweeters. One pair carries the signal from the amp to the Tweeter, the other pair passes it from the Tweeter to the Mid on the dash. I can't remember exactly how or why I went wrong, but I mistakenly connected the new Tweeters to the leads that passed through to the Mids, not to the actual signal pair. As a result, I ended up with no working Tweeters or Mids. I switched to the other wire pair, and all Tweeters and Mids worked again. t might take a bit of non-destructive experimentation to identify the feed wires vs. the passthroughs, and it's different on the right A-pillar and the left.
Also... the stock speakers in the doors have their own, glued-on mounting brackets, and it seems that any aftermarket speakers will also require some bracket but can't really reuse the stock ones. I bought all four door speakers from Crutchfield, who automatically bundled the correct mounting brackets for a 2006 RX.
Finally... as others here have found, while the dash speakers are purported to be 3.5", the 3.5" Kicker CS's I used are marginally too wide and too thick to fit in Lexus' precision-fit dash mounts. I mean, they'll fit in the space, but you won't be able to get the stock dash speaker grills back into place. I had to use a Dremel tool to both enlarge the dash recesses and thin down the rubber flange around each speaker.
It wasn't a quick or easy project by any means, so I'm really glad it's ended up sounding as good as it does.
STRUT UPDATE:
Installed the struts approx 500 miles ago. So far so good. I think the ride quality is somewhat more firm, but I like a firmer suspension myself. It is difficult to say as the struts were I think on our way out when I purchased the vehicle, so my "normal" is probably not factory. Installation went fairly smooth with only a few minor hiccups but minor in the process.
cfgoldman
02-07-14 02:55 PM
