Annoying Squeak
Annoying Squeak
Ok so this past weekend I took on the job of replacing my spark plugs. That sucked, but that’s another story. While I had the engine exposed I thought I would wash it with some engine degreaser and water. I did that and then blow dried it was leaf blower and let it sit for numerous hours before starting. It started up fine but the next day I now have a squeak coming from serpentine belt area.
This is only happens when in idle or very low speeds. If I spray a little bit of oil on the belt it goes away. So the first thing I did was replace the belt and still the same squeak. That was a dayco brand and I read they are bad for pulley out of line. So I bought a Continental , went ahead a bought a new lower idle pully and pulled top one off and greased the bearings. None of this helped. Still have the same annoying squeak. I really don’t want to take to a shop so I’m hoping someone on here has an idea?
Also I tried to spin each pully manually the best I could and couldn’t hear anything. The other thing is if I put a wrench on tensioner and back off the tension a little then the noise stops as well. So I’m thinking maybe the tensioner is bad? This all started after washing the engine bay. Car has 115,000 on it.
Thanks,
Frank
Thanks,
Frank
omarg
12-03-07 01:37 PM
