car alarm suddenly working each time I open the door, how to disable?
On a 2004 RX330, I never heard the car alarm until now, after I installed a car stereo and changed the battery. How can I disable it? Permanently is fine. I'm only using the key, as I can't get the remote programmed - I live on an island in the Caribbean.
I know you can disable the alarm in techstream, but that probably doesn't help you if you don't have techstream. You can however try to program the remote. Make sure the battery in it is good.
Remote Programming:
1. Begin with the key out of the ignition.
2. OPEN and UNLOCK the DRIVER'S side door. CLOSE all other doors including the trunk.
3. Within 5 seconds INSERT the key into the ignition and PULL it out TWICE.
4. CLOSE then OPEN the DRIVER's side door TWICE.
5. Insert key INTO the ignition then REMOVE it.
6. CLOSE then OPEN the DRIVER's side door TWICE.
7. Insert the key INTO the ignition and LEAVE it in ignition.
8. CLOSE the DRIVER's side door.
9. Switch the ignition to ON then OFF.
10. REMOVE the key from ignition.
11. The door locks will now cycle to confirm the vehicle has successfully entered programming mode.
12. PUSH and HOLD the LOCK and UNLOCK button for 1.5 seconds on the first remote being
programmed. As soon as you let go PUSH the LOCK button and HOLD it for 2 seconds.
13. The door locks will cycle to confirm successful programming of the remote. If you have any
additional remotes to program repeat step 12 if you have no additional remotes proceed to step 14.
14. OPEN the DRIVER'S side door. Programming is now complete.
Remote Programming:
