I did a BI-Xenon retrofit with AFS.
Hello everyone, I want to share the work I did to exchange the old projectors with newer G5 bixenon projectors and the additional work I did to the headlights.
- I used special brackets from Aliexpress to mount the G5 projectors in to the spot of the old RX330 / AFS projector.
- The high beam function was spliced in with the halogen high beam.
- Also I added LEDs around the high beam bowl to get a white DRL
- I added white LEDs in the bi-xenon projector to get a devil eye optic when the DRL are on.
- Additionally I exchanged the side markes to be amber LEDs behind the stock white reflector.
This was a two stage process because the first time I only exchanged the old burned projectors for newer RX330 projectors.
The old burned projector and the newer RX330 projector:
Since the second set was also a little burned when I put it in I started to research on other options and I found the brackets and G5 projecturs suitable for my headlights.
The bracket to adapt the G5 projector into the spot of the RX330 projector
the G5 projector found its new home
The LEDs for the DRL:
The leds for the devil eyes:
LED board for the sidemarkers:
DRL and devils eyes on:
More information can be found on hidplanet.com in the projector retrofits section.
https://www.hidplanet.com/forums/for...ctor-retrofits
Congrats. I love proper HID retrofits. HIDplanet is awesome- i did two retrofits with the 7th gen accord with tips from them. The retrofits i made had better light output than my stock IS350 LED beams.
For the RX I could see myself doing a quad retrofit but on the other hand I so like my Led DRL in the highbeam.
