Headlight leveler
My '04 RX 330's headlights are stuck in lower position. The dash light for it is on most of the time and off some of the time. Is there a way to bypass the leveling system and fix the lights to one position?
Does auto-leveling work? I.e. do you see headlights movement when you turn them ON (at night on the wall in front of car)? If YES, then you need to adjust headlights manually (for example, https://raybuck.com/how-to-adjust-align-headlights/), otherwise, you need to repair headlights auto-leveling system first.
