Power stearing belt replacement
Hi, I'm replaceing the power stearing belt and alternator belt on my 04 rx 330.
I believe I have the power stearing pump pushed
up against the block all the way and still can't pry the belt on?
I'm woundering if that is normal or I have a defective belt?
Thanks,
Mark
Thanks,
Mark
Hi friends,
I had the same problem when I installed mine.
The belt was tight as hell and the PS pump was loosened as far as possible.
I took a prybar and worked the belt on the pulley.
My car is 2004 RX330.
