2008 rx350 seat memory buttons not working
Hey gang,
recently bought an 08 rx350 and just realized the seat memory buttons not working. So far I’ve tried disconnecting and reconnecting the harness ( waited 5 mins ) and same with battery. Doesn’t beep.
any help is appreciated! Thanks.
The buttons for the seat memory are just that - buttons. When you press a button, it sends a signal to the power window master switch. The power window master switch then sends a signal to the seat motors via the computer data lines.
Check that the white/black stripe wire on the seat memory buttons is connected to ground. If the ground is good, then my guess is that the power window master switch is the problem.
damon1964
06-17-07 09:35 AM
