Solid AFS Light
Hi all. Our 2008 RX350 has an AFS Off light on, but it is solid, not flossing. I immediately checked the arm in the back suspension, and it is neither snapped nor seized.
Does anyone have any indication of what it could be or where to look first?
thanks in advance
thanks in advance
Did you check the button on the driver side panel under and to the left a bit of the steering wheel? I know there is a button on mine in that area that if pressed in will turn off the adaptive lights and a indicator will show afs off.
Margate330 (12-18-19)
