120K miles, first time sparkplug change
I'm planning to do a major maintenance for my 2005 RX330. These are what I had in my mind, can you please recommend and share your thoughts?
Thanks in advance!
Sparkplugs
Coil (I read some people suggested to change when changing sparkplugs?)
Air and cabin filters
Oil change
Transmission oil change (is this necessary?)
Gas filter (is this necessary?)
It sounds like sparkplug change is the biggest job here, please let me know if I should do something else together.
(I already had the water pump and timing belt changed)
Thanks in advance!
Sparkplugs
Oil change
Jake, yes it's a big job, just did it for the first time yesterday (see my post). It took me about 4 hours to do. I ordered my parts online, i changed plugs, coils, and don't forget air intake and throttle body gasket.
The bolt from hell was tough to get out.
i changed the coils cause i don't want to have to go back there for a long time.
fab
fab
Yes, you might as well change your ignition coils too. You don't need to, but while you're working on the plugs may as well.
Fuel filter I would recommend changing.
Transmission fluid change is important, but you also need to change the pan filter if you want to do it right.
Do you have any check engine light?
you might also want to inspect and replace your PCV hose, add some fuel system cleaner to an empty tank of gas, have your injectors inspected, etc.
Thanks in advance!
Sparkplugs
Oil change
Thanks in advance!
Sparkplugs
Oil change
to gain access to the rear coils and plugs. As far as a fuel filter goes. I’ve had my rx a bit over 3 years now and haven’t had to touch that at all. I believe u shouldn’t have to as it’s one of those “permanent” filters that just sits in the tank I think.
No I don't have the check engine light on.
Don't they usually change PCV hoses with timing belt/water pump change? I have to see.
Thanks for the replies.
yes the rear spark plugs are the pita!!! And yes it’s a big job! It might take ya 3-5 hours to do depending on how much experience u have working on vehicles. When I had my sisters husband help do my rear ones it took I would say about 4 hours including a quick lunch break. There’s no way I could have done it myself because of the bolt from hell that holds on the manifold which has to come off
Lexuswiz (12-31-19)
If only Lexus put the 2JZ-GTE in an RX LOL. This is why I also love V8's and BMW inline 6's.
BMW V8's are nothing but problems but their inline 6's are excellent.
Felix (01-01-20)
it’s a ton easier to do the plugs and coils on a lot of other engines besides these Lexus v6 engines! For some reason I guess the designers felt we consumers needed a “challenge” and so they chose the rear plugs n coil packs. Go figure! Lol 😆
(prevents adding three coils to your local land fill)
Margate330 (01-01-20)
Try changing plugs on a LS4 or a w/p on a 3.5 Ford in a fwd platform or a starter on a Northstar......Every vehicle has some kind of accessibility issues.
oh I’m sure no doubt! Yea other engines do have their share of access issues which has to make ya question “what the heck were they thinking” lol
It is good practice to replace the Coils in the rear while doing the Plugs. Save these Coils in case any of the front Coils fail, you use one of the rear spares.
When I had the Timing Belt done, my mechanic did the Spark Plugs. Silly me, I should have replaced the back Coils then. My Cylinder 5 Coil in the Rear failed and of course, I had the other RR Coils replaced. I now have 2 spares.
I had to spend a couple of hundred $$ that I could have saved if I was intelligently thinking...my loss your gain.
