Turning my 330 off with the aircon on?
Before turning my rx330 off, should I always turn the aircondition off? Or does this not matter? Please advise!
Thank you!
Sonny
Thank you!
Sonny
Don't know how different the 330 AC system is from the 300.
If you live in low humidity climate, it does not matter if the ac is on or off when you turn off the RX.
My family always gets mad at me, as I turn the AC (comp) off whne we are about 2 min to park in the garage. In addition to a smaller puddle in the garage, there is no musty smell in the cabin. [Dig old posts if you are interested ... but then they apply for 300]
Salim
Salim
Salim
Salim
Thank you for the quick response! Just one more question out of curiosity/concern, when you two mentioned "less musty smell," and "smaller puddles," does this mean that the water that should drip out of the car stays in the car? Wouldn't this cause bacteria to build up causing bad odors in the AC? Or am I getting this all wrong?
Thank you Salim and CK6Speed for your input!
Where one AC system is different from other is in the collector compartment and drain orfice. Some people have had an issue with RX300 in this regard. I have not run into this problem as I follow my ritual in RX and other cars that I drive/drove.
Salim
MrUnicorn
08-04-16 10:33 AM
L8Apex
02-14-12 06:52 AM
