2nd radiator???
Hi Guys,
Managed to get a condenser for my car so got the air con working again. However my mechanic said that there is a small radiator behind the main radiator which he believes is to cool the hybrid batteries. He says it's in a bad way and recommends replacement. Does anyone know what the name is for this small radiator and has anyone had to replace it in the past?
I think you are referring to the radiator that is part of the inverter cooling system. Lexus simply calls it "radiator". It is part number G9010-4801. You didn't say what year your car is, so your car may use a different part number.
Here is a link to a parts diagram - https://www.mylparts.com/v-2007-lexu...ing-components
Burroo67 (02-06-20)
Burroo67 (02-06-20)
Many thanks, unfortunately RockAuto are out of this part at present so need to save my pennies in case I need to buy a new one (a small fortune for such a small part, but my mechanic says the RX is sound in all departments other than this inverter radiator and i love the car).
I can get a second hand one from a Lexus car breaker for £120 delivered, it has a 12 month warranty but I'm not too sure it would be the solution as the part would be probably as old if not older than my car!
Burroo67 (02-06-20)
professorm
08-01-19 12:57 PM
