ABS VSC BRAKE Lights Help!
I know this is a common issue.. I took my car into a local shop when the lights came on about a year ago. He said the code was reading a bad wheel speed sensor, passengers side rear. I recently replaced that sensor. The lights are still on. I have tried disconnecting the battery, that didn't help. I have also came across a few threads on here about bridging the terminals on the scan port. I tried that, and either the locations of the terminals are incorrect for my car or I just didn't do it correctly. Does anyone have the CORRECT location of the terminals to perform the light reset? The shop that I used to go to has since closed its doors, and the other local shop is quoting me $100 just to look at it.. Any help is appreciated!
I just did another search and found a thread that didn't pull up earlier while searching using my phone! I'm going to attempt this and report back.
https://www.clublexus.com/forums/rx-...ping-help.html
Ok. I followed the instructions there and the lights did reset. Cool. Unfortunately they came right back on after driving around the block. There is something wrong. I guess I need to find someone that can read the code. I hope the tone ring isn’t shot. When I replaced the sensor I looked down the hole and the small part of the ring that I could see looked fine.
