Most common Causes of coolant leaks on 2007 rx350
Hi my rx 350 is leaking coolant ,and I want to know most common causes!? the small plastic reservoir is bone dry ,but the radiator still has coolant ! I am taking the car to the mechanic mon. The 24th ! I will know for sure ,but it’s staying parked till that time !? I am just curious if any other fellow Lexus RX (2nd gen) have had any similar problems? I know the water pump is a common problem ! No water pump trouble yet , so maybe the water pump!? Thanks look forward to feed back !
x2^^^ Check the plastic tanks that attach to the radiator......I'd replace it w/ a all alloy radiator.
mak89
SC- 1st Gen (1992-2000)
03-23-15 07:06 PM
Patsum
07-27-12 04:29 AM
