Need lelp with maintenance p/n
Hello, can anyone help with part/numbers for RX400h maintenance parts, such as: motor oil, coolant, transmission oil and etc.
These are part numbers for a 2007. They might be different for other year models.
cabin air filter - 87139-06030
air filter - 17801-20050
engine oil filter - 90915-YZZG2
engine oil drain plug gasket - 90430-12031
engine oil, 5w30, quart - 00279-
anti-freeze, pink, sllc2, 1 gallon, 50/50 mix - 00272-SLLC2
Thanks, basically i search P/N for liquids, because i found another parts in on-line catalogue, but this catalogue doesn't contain any liquids.
I think you mean 00279-0WQTE when you say about motor oil, but Toyota parts say "THE PRODUCT IS NO LONGER AVAILABLE", maybe this P/N suppressed by another?
I found probably over a dozen part numbers and every time I found a part number for motor oil, the lexus parts list always said something like the product is no longer available. Toyota seems to have all types and weights of oil. synthetic and dino, 5w20, 5w30, 10w30. I even found one that was 10x40. If you want to use oil from Toyota, my suggestion is to search for TOYOTA OIL on Amazon or E-bay.
BTW, all Toyota motor oils will start with 00279. The first 5 digits of any part number is a category or type of part,
I don't use oil sold by Toyota so I lost interest in the oil part number search. My suggestion is to use one of the motor oils commercially available as long as it has the API rating of SM. SN was the standard in 2004 and was updated to SM in 2011.
ATF # 08886-02305 has been replaced by 00289-ATFWS. Any that you find is old stock.
ATF # 08886-80807 is a 1 liter can sold in Japan, not in the U.S. It is printed in Japanese.
Other numbers that I have found -
In this group, most of these items come as a multi-pack, as little as 4 and as many as 12. Check carefully if you try to order these.
Toyota Brake Fluid, 12 OZ, Polyalkylene glycol based, 00475-1BF03 or 00475-1BF03-LX
Toyota Windshield Washer fluid Concentrate, 1QT, 00475-00WWF
Toyota PAG Oil, 7 oz, (for a/c compressor) 00289-AC897
Toyota Chain & Cable Lube, 12 oz spray, 00289-CCL01
Toyota High-Performance Penetrating Lubricant, 12 oz spray, 00530-1PL00
Toyota Tire Mounting Lube (11 oz.) 00289-1TL00
Toyota Tire Mounting Lube (1 gallon) 00289-TLG00
Toyota Top Engine Cleaner, 11 oz, (requires Top Engine Tool P/N 00289-TECTL) 00289-1TE00 (this is Seafoam-like product)
And i think 00289-ATFWS not fully replaced 08886-02305, because 08886-02305 it 4 Liter canister, 00289-ATFWS have only 0.95 litre. And they have 08886-02303, it's same things, but in 20 liter canister.
And I found little more p/n:
Toyota 0W-20 Fully Synthetic Motor Oil - 00279-0WQTE
Toyota 50/50 Pre-Diluted Super Long Life Antifreeze/Coolant - 00272-SLLC2
Disc brake caliper grease - 08887-80609
Rubber grease, Lithium soap base glycol grease - 08887-01206
Disk brake shim grease - 08887-80409
And i think 00289-ATFWS not full replace for 08886-02305,
It seems that Toyota is constantly changing the part numbers on the oil. I have no idea why. But some of these oil numbers are not intended for the united states, although people are getting their hands on them and selling them here. Read how the can/package is printed. If it is not American English, then it was intended for somewhere else. For example if the measurement is metric, such as .95 litre, it was not for the United States market, but it may be the same exact product inside. FWIW, .95 litre is one quart and litre is not the American spelling of the word.
I known about litre and quart, but another two canister have only Litre marking, and only 00289-ATFWS used double marked 946ml/ 1US quart, i'm writed in litres for easy comparison.
Was interested in similar inquiry regarding the following brake fluid part numbers;
00475-1BF03 and 00475-1BF03-LX
Have since confirmed the only difference is branding. 00475-1BF03 is Toyota label and 00475-1BF03-LX is Lexus label.
You are probably right. When you look up parts for trim pieces that are inside the car and come in different colors, the main part number (xxxxx-yyyyy) will be the same for all the various versions. The dash code after the part number will vary for the specific color.
