For some reason lately after every time I stop to fill up w gas after; my cruising range keeps going down every time and now I’m not getting as much range as I use to. I use to get like 350 miles or more per tank;
now after I just filled up Its down to 311 miles. What’s up with this? Fuel filter going bad? Fuel pump going out?
I get about 300 miles to a tank all around....I'm seeing a lot more ppl on the roads/freeways now vs last month as well. I use the odometer vs the how far to go.....btw the fuel filter is hooked to the pump, if you have a pump going out you'd know it. Like mentioned above, using the a/c uses more fuel........
Loaded up with turtle top and rear hitch cargo Got 24 mpg on 900 mi trip. Premium fuel and kept it around 65-70. Drove with my foot not the cruise
If you go over 70 mileage drops off.
