Another knock sensor error question
Hi everyone. I've been very active on other marque forums and frequently consult this one, but haven't needed to post. I guess we've been lucky with our '04 Rx330 so far. (124K miles)
We now have the infamous P0328 code plus the VSC warning light. I've cleared it several times, disconnected the battery and greased the gas cap but it only stays off for a short while.
I've done quite a bit of searching here and am zeroing in on two possible reported explanations:
1) The mysterious connection between the brake light switch and error lights that some swear is responsible for many codes, or
2) There actually is an error from the knock sensor - possibly due to coolant leaking on the wiring harness.
I'm afraid number 2 is winning because we do seem to be losing coolant slowly and using a borescope camera I can see a good deal of orange "stuff" in the valley under the intake manifold.
That said, I'd love to find out that a new brake light switch would cure whatever this is. I'm reluctant to go with aftermarket based on input here so this swap would cost about $100 in exorbitant Lexus part pricing. Maybe cheaper if there's a trusted online source for OE parts - is there? And if anyone can confirm that a 4Runner switch is the same that would be good also.
Regardless, I'd appreciate any thoughts on whether it's worth the time and $ to replace the switch before jumping into serious disassembly.
Thanks in advance for your help.
Ron
Ron
Answering my own question in case it might be helpful to others down the road. Turns out I did not need to replace the brake switch, nor resort to expensive or time consuming intake manifold R&R (yet.)
Helped with input found in another thread, I was able to find and cut the wires going to the faulty knock sensor and divert them to a new sensor mounted on the engine in a location that is accessible. $25 in parts and it worked like a charm. I can post more info and photos if anyone is interested.
We'll someday need to fix the minor coolant leak under the intake manifold and will restore the proper sensor arrangement at that time. But it's a slight seepage and not worth a $1,500 repair tab (or 5-6 hours of my own time) to go after just now.
Ron
Ron
Bluetheron (05-18-24)
Ron
Ron
thanks
Ron,
I also have an "04 rx330 throwing off a P0328 code & would love to see photos of how you repositioned the knock sensor.
BTW - did you also have check engine & VSC lights on & did your knock sensor fix turn those lights off?
thanks
Chiliman
thanks
Chiliman
Let me put some photos together and also look up the link(s) that helped me with this. Will post once I get it together. In the meantime:
Jeffro - you said codes. Does that mean you have both knock sensor codes? P0328 and P0330, or just one?
Chillman - yes, either knock sensor code will turn on the CEL - and from what I've read, whenever there is a CEL light, for some reason it also lights up the VSC lamp. This also puts the ECU in "limp mode" - which as you've probably noticed makes the car drive like a slug. And yes; once I was able to get a good connection to the replacement sensor, they went out.
Ron
Ron
if it were me i would not bypass the sensor because if u do bypass it and there really is a issue with one of the sensors then u may not know it.
Ron
Ron
Finally, not to beat this much further, there are several threads on this topic and many people who pulled everything apart (as I'll do at some point) confirm their issue was coolant seepage-caused corruption of the sensor connector. Once I got access to the wiring harness I was able to check resistance and both my "good" OEM front bank sensor as well as the new replacement read 0.2 Ohms, while the wires going to my "bad" sensor showed 15 times that. FYI - here's a bore scope photo of the built up crystallized coolant "mountain" in the valley between the banks (where the knock sensors and connectors are mounted.) At first I thought a large family of mice had built a nest in there.
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/640x480/ipc_2020_08_07_13_54_25_1860_7e214d5a2eb5e4c1973a39bca6369bf0abed3070.jpg)
OK, the CEL popped back on about 15 minutes after battery cable was securely fastened - reran diagnostics & still Knock Sensor - P0328. So Back to square 1.
Ron,
Yes, car is sluggish & highway gas mileage has dropped from 23 to 19 mpg. Do you think replacing both knock sensors will solve sluggish engine problem?
Thanks,
Chiliman
Thanks,
Chiliman
In answer to your 2nd question, yes, everything should return to normal once the ECU is no longer getting a fault signal from the sensor, causing it to severely limit revs, retard the timing and do other annoying things.
The knock sensor is there to detect if the engine is not running properly (i.e. knocking). The P0328 may be a valid problem, not just a bad knock sensor. It may be difficult to determine which is true. Do you ever hear the engine pinging?
No pinging. No overheating. I’ve owned this Rx330 since ‘07. 160k miles. Have had multiple diagnostic tests & only thing that pops is P0328. Just got back from 3000 mile road trip & all was fine. No CEL & no acceleration problem. Now CEL, VSC, bad acceleration & mpg down ~20%. If it were oxygen sensor- wouldn’t a code show it?
I would expect an O2 sensor to throw a code, but there are no guarantees. It would be rather rare to not get a code. A bad upstream O2 sensor will cause poor gas milage but if you have the knock sensor code, that will cause the ignition timing to be retarded, which will reduce gas mileage also.
Since it seems that the engine is running OK, then you may have a bad knock sensor. You can check the ohms of a knock sensor, but I don't know what the ohms reading should be.
Both my "good" sensor and my newly purchased replacement read 0.2 Ohms. The one that was throwing the error code read 3.0 Ohms. If you want to remove the glovebox and disconnect the connectors at the ECU the measurements can be taken there. I took mine from the connector on the engine once I was able to access it.
I promised more info on my sensor replacement project and just about have that put together. I hope to be able to post later today.
Ron
Ron
