How to program rx330 remote and transponder
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Hi, everyone, I just bought a flip key of eBay and trying to program the key, searching, and tried a lot of ways, I found out below those 2 ways are working for 2004 lexus rx330
Programming Procedure for transponder
- First, close all doors
- Insert master Toyota key in and out of the ignition cylinder 4 times. On the 5th time leave the master key in the ignition cylinder
- Open and close drivers side door 6 times
- Remove the master key from the ignition cylinder.
- Verify that security light on the information display is solid, indicating that the car successfully entered programming mode
- Insert new chip key
- Watch security light blinking for about 60 seconds
- When the security light goes out, your new key is successfully programmed
- Remove the new key from the ignition cylinder
- And finally, verify that your new key is able to deactivate anti-theft system: security indicator light on the information display should disappear when inserting properly programmed key into the ignition cylinder
1. With the key out of the ignition, unlock and open drivers door (all other doors must be closed)
2. Within 5 seconds,
Insert the key into the ignition (Do NOT Turn it) and Pull key out.
3. Within 40 seconds,
Close then open the driver's door.
4. Within 40 seconds.
Insert the key into ignition and leave it in the ignition.
Close the driver's door. Turn the ignition to ON then back to OFF (Do NOT Start or crank engine).
Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the door locks do not cycle at this point or try the alternate procedure listed below.
6. Within 40 seconds,
A. Press the lock and unlock buttons on the remote simultaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons, press and hold the lock button by itself.
Within 10 seconds, the door locks should lock and then unlock once indicating successful programming.
(If the door locks cycle twice, repeat steps A and B in step 6 as the remote was not accepted)
Repeat steps A and B in step 6 for each new remote.
7. Open driver's door to exit programming mode.
glentamur
08-17-20 09:12 PM
fj40ih8mud
10-18-15 05:32 AM
