Radiator Leak HELP!
Radiator Leak HELP!
Finally found the leak i've been battling with. Both driver/passenger have fluid around the same area. This isn't a drain bolt I believe, I couldn't find anything while doing research. Any ideas? Should I try to tighten? Every day it goes from full to low fill line (checked when cold) (driving less than 10 miles a day) so it's leaking a decent amount. It looks like the original rad (240k mi). Any tips or should I replace?
yup! definitely sounds like the radiator has finally met its match so to speak and finally bit the dust. 240,000 miles is definitely a lot of use for a original radiator so yea its time for a new one.
Jacob0015
02-25-14 07:08 AM
