Recommended Maintenance Performed
Hi, I am new here and have always wondered what encompasses "Recommended Maintenance Performed" when read from a Carfax? Anyone know what Recommended Maintenance Performed means when a car is at the 50K, 70K 100K stage. Is it ever considered Recommended Maintenance Performed to have the timing belt changed by default at this time in the Lexus rx 330?
Also, when buying a used Lexus 2004-2006 rx 330, how do you know if the timing belt has been changed in recent history? Is there a sticker placed somewhere in the engine compartment stating that it has been replaced?
Just curious. Thanks all...
Dennis
Dennis
Dennis
Dennis
I read carfax "recommended maintenance/service" with a grain of salt. It's most likely the bare minimum a dealer or indy will do and therefore it's barely documented. Always ask for service records, if any.
If Lexus did the belt, there usually will be a sticker on the engine cover or the front timing belt cover. But I have seen instances of even Lexus not putting the sticker and I have personally never seen my indy put stickers.
If you end up getting a 330 with no records of a belt change, I would go ahead and change it for peace of mind. My 330 was used and had little service records, I went ahead and changed the belt, been problem free since.
crz95
11-21-19 05:41 AM
