Replace spark plug wires together with the plugs?
Hello Lexuers!
I will replace the spark plugs and I would like to know if I should also change the wires?
The spark plugs I will use Bosch FR7NII35U.
Thanks for the assistance.
So I'm concerned, because it's still the factory plugs.
Any special reason?
Manual tells to replace spark plugs every 120k ))) So, you can safely drive the next 60k.
NGK were always the best OEM spark plugs replacement (NGK is the well-known supplier for car manufacturers).
I understand that mileage is important when the car is running, but what about when it runs low in many hours? It's been 12 years using the same plugs!
About NGK and OEM, wouldn't it be better to use Denso instead?
Thanks!
i would stick with denso plugs which is what comes from the factory on these rxs. As for the wires; it really is up to you whether u do it or not.
oscarneto (10-15-20)
2008 Only 42,000-Miles ❓
If it’s idling fine leave it be.
If idling rough on Premium Gas, ofcourse. I’d first change air and cabin filters. Then clean Throttle body and MAF Sensor.
Don’t use any gas additives at all.
Set of Michelin LT tires from Costco would be a better investment if original still on.
Remember: “Less is Better.”
per lexus the plugs should be replaced every 120,000 miles. Thats what lexus says.
Bogey2 (10-16-20)
Amazing find 👍🏽
The tires I change them to Yokohama G055.
Already changed engine/differential/automatic transaxle/transfer/steering oils (Castrol), air/oil/cabin filters (Mann) and break fluid (TRW). Now I am (was) concerned about the spark plugs, but will wait.
Is hard to clean the throttle body and MAF Sensor?
I have a 17 years old rx330,82 k miles with almost city driving 2-4 miles a time,replaced the plugs and really there was NO NEED ,,LOOKED LIKE NEW,,SO DO NOT WORRY
oscarneto (10-17-20)
Just so you know, the "spark plug wires" are part of the engine wiring harness, and who knows what an entire harness costs, but I bet there are possibly 40 connectors on it in total, not something you want to mess with.
Cleaning the throttle body is not hard it you remove it. I did mine, and after restarting the car, it idled high for a few minutes then settled down to normal idle quite nicely. I did not move the plate much, just carefully cleaned the carbon in both sides of it. Battery was disconnected.
Clean Throttle body & MAF
Thanks! I searched it for a year!
Two small phillips/star screws will let you pry it off. TOUCHING THE SENSOR PRONGS WILL CONTAMINATE IT.
Just spray outside and inside sensors with MAF spray cleaner only.
Removing all the flexi duct from AirFilter box to Throttle body Metal housing will expose the butterfly throttle flapper and the carbon accumulated around it. Spray the area with Carburetor spray cleaner only. Wiping the inside with a soaked micro-cloth on a stick/wand will help.
Always do above first when idle is rough. Premium gas ⛽️ 93/95 Octane is used by Lexus.
I’ve seen Lexus that have survived for decades on Regular gas ⛽️ 87/89 Octane and their plugs are rusty brown with plugged Catalytic Convertors, sub-standard performance 👎🏽
Ps. I wish Costco sold Yokohoma and Toyo tires !
Use Denso Spark Plugs. That's OEM. MAF (Mass Airflow Sensor) periodic cleaning is recommended. Use the "Mass Air Flow Sensor Cleaner." CFC Brand is a common brand.
